Nitrous wet plate???
I'll need the whole kit but what's the difference in the 92mm lsx wet kit and the 92mm fbody wet kit??
http://www.nitrousoutlet.com/efi-wet-nitrous-systems/gm-systems/nitrous-outlet-92mm-lsx-plate-system.html
http://www.nitrousoutlet.com/efi-wet-nitrous-systems/gm-systems/nitrous-outlet-92mm-fast-intake-98-02-f-body-plate-system.html
Pretty sure the F-Body specific kit has the hard lines that go from the noids to the plate and the non F-Body kit does not (they are the braided lines). The F-Body kit also has the specific mounting brackets for the noids that attach to the fuel rail. You can see it in the pictures if you look closely.
http://www.nitrousoutlet.com/efi-wet...te-system.html
The LSX 92mm system has universal solenoid brackets and braided lines.
