Fastest stock blocked nitrous ls1 383?
Fastest stock block ls1 383 on nitrous?
What is the most people have sprayed a stock block ls1 383 with? Please include build information and times.. I'm trying to figure out what I can get away with..
I know what people have been hitting stock bottom ends with I'm curious about 383
With that big of a shot on stock bottom end it's on borrowed time BUT if your going to do it make sure tune is spot on and you got the fuel system to handle it. With stock bottom end there isn't too much that you can do as far as " protecting" it. That's if that is what you are asking.
I'm not asking about stock bottom end cars I've sprayed mine with 200 for 3 years now..I'm wondering if changing to a 4" crank will matter and how much people have sprayed a ls1 block with 383 internals 4" crank, 6.125 rods, and 3.905 pistons..and got away with before the clynder walls started to go
