Nitrous on launch
Nitrous on launch
How much can you spray off the line and not have traction issues?
Basicaly my question is at what point do you need a 2 stage and when would you want to bring the 2nd stage in.
Ls1tech & Truck Sponsor
Well if it hooks that well, I would bring in 200 off the line and and 150 on the second stage, or vice versa if you have trouble hooking 200.
The other way you could do it, is run a progressor, and jet the thing for 300 or so, and bring it in at 50%, and set it to bring the full 300 in after the 60 ft.
Sounds like the car hooks pretty well.
Thanks,
Garrett
Thanks,
Garrett
Thanks,
Garrett
Thanks,
Garrett
Now if you're existing kit won't flow as much as you want, then you can look into a bigger kit and a progressive, or a 2nd stage with a controller.
As said, how much you can hit off the line can only be determined by testing. A car with big tires and wheelie bars can obviously hit it harder off the line than you can with a 275/50/15 drag radial. I'm honestly surprised you are able to hit it with potentially 650 rwhp on those little tires off the line as it is.
I have no idea what my coupe makes at the wheels, I'd guess on the nitrous I'm somewhere close to 1000 at the crank. On a 275/60/15 First Gen Mickey radial, I use the NOS Mini to control the hit. I don't have any fancy timing controllers, just a digital 6 ignition with 16* total timing on a .130 jet single entry plate. If the track and tires are good, I can bring it all in usually by .8 seconds with a start percentage of 20-25%. If prep or tires are weak, I slow it down to 1.2 seconds or slower. I've been a 1.26 sixty foot on those first gen mickeys, but they have a little more sidewall than your 275/50 tires.
