Is the br7ef the same as bkr6egp?
Today I went to the out parts store and asked them for the ngk br7ef #3346 and they gave me the ngk bkr6egp #7092. Is this the same spark just with a different part # or is it completely wrong?
No it is not the same. It is an extended tip fine wire plug and 1 heat range hotter. I wouldn't run that plug if you are spraying. Most of the G plugs I have seen are usually ran in a hemi style head like motorcyles and imports.
got another question on the br7ef. i ran them on my ls3 camaro and it ran fine. traded and did same mods on a ls3 vette and it runs like crap. with them. i gapped them at 035. think i should shorten that gap up to 032 or so. car runs great on tr6. but its def to hot of a plug. alrdy melted 2 down in 1 pass on a 150 shot with 11* pulled. 6 on my camaro was fine. both same amount of timnig. any suggestions ?
im talkin about on motor and dd it its not running smooth at all. low rpm miss from time to time. nothing i cant live with. would rather keep the br7's in, then melt more plugs.
