NX Proton mini-review
I was having a hard time hitting the tires hard enough with my combo and 3200 stall to get a decent 60'....even with 4.30 gears, that was I looking at a $1200 billet 4400 stall so I might run bottom 11s, high 10s. My best ET was 11.67 @ 119.6mph with a 1.806 60' with no tire spin at all.
An event was coming up for a rented track and no NHRA tech, and my car being a true daily driven street car, baby seats and all, I wanted to make sure I got my opportunity to run a 10. Being on a budget (layed off from work, father of two, full time student, yadda, yadda) I was given a generous cash donation from my mother on my birthday so I could go racing. That expensive converter is a no-go...way too expensive right now. Then the thought came to a good shot of nitrous to give me that little oomph off the line I needed. Just about the only thing in my price range was the Nitrous Express Proton system. I had previous contemplated doing a 50 or 75 dry shot into the MAF just to help get that 60' down, but my MAF g/sec is already near max and my 42lb injectors are already past 80%. More than one person I trust told me to just go wet. So, I did.
The week leading up to the event I put the bottle and bracket in one evening. I stripped BOTH plugs in the bottle trying to remove one for a pressure gauge. Guess they used a healthy amount of red lock-tite or cross threaded them in there! I ended up with a flow-through fitting to put the gauge in instead. I used a house framing bracket to mount the solenoid housing and got that spliced into my fuel system. I really like that housing...I'm designing a billet bracket for it at school. Should be killer. Grabbed the piece of intake tube needed for the nozzle and drilled it and installed the fitting on yet another day.
Looked basically like this when I left for the event, except the n2o feed line was in place.
Attachment 722136
All work was performed in this parking lot.
Attachment 722617
Got to the track, and on the first day of the two day event I focused on getting the car setup right, hooking and running the n20 tune a few times without the nitrous wired. Then that evening I wired it all up and went to sleep in my wonderful tent. It was cold.
Attachment 722618
My two runs in the morning were smoke shows off the line...something that never happens with this car. Track prep was pretty iffy. Time was running short, so I said screw it and with my fuel level running low, I plopped in the 100 hp jets, opened the bottle and armed the system. I left the line easy and ran a 11.67 @ 96.14mph letting off just before the 1/8th because it went dead lean and started breaking up. 1/8th mile was 7.254 @ 98.9mph compared to 7.575 @ 94.8mph N/A. Fuel gauge read 1/4 full, but that apparently gets sucked dry enough by half track to uncover the pickup. Bummed a ride into town to grab 5 gallons of 92...not a chance I'm paying $12 a gallon at the track for race gas I don't need.
Back with more than 1/2 tank of gas, I was ready to go again. Still hit it pretty soft out of the hole but it was enough. Ran a 10.98 @ 126.4mph with a 1.735 60'. Other guy was a sport bike of some kind. Attachment 722619
If you look at the TPS% you can see how conservative the launch was.
Attachment 722620
Then we ran out of time, had a top-end crash and that ended the day. But, this Proton kit was priced right, went together easy and just simply worked. I'm a believer now.
tldr; I installed a NX Proton kit in a parking lot, wired it in the pits and went from 11.67 N/A to 10.98 with a 100 shot and a conservative launch.
Attachment 722136
Attachment 722617
Attachment 722618
Attachment 722620
Thanks, you guys made it easy! I'm sure I will get to mid-10s without much trouble before I run out of RPM and have to swap gears. And if it was missed earlier, this is my only car and I drive it every day and transport my kids in it. Happy to tell people, "it runs 10s" when someone corners me at a gas station, grocery store parking lot, school parking lot, etc.
Okay thanks - I not overly computer savy and all my tuning was done by a professional. I'm looking for the easiest/laziest way to pull timing. Maybe it's time I learned HP tuners lol
It looks like you are using full pressure on the fuel side. I thought you had to regulate the fuel pressure down to 5-6 pounds for the nitrous setup. How did you get that to work?
Thanks
Thanks
Specific example: look at this one, the last table for GM fullsize pickup. For 150 nitrous, use nitrous jet 62. For fuel pressure 9-13, use 46 jet. For fuel pressure 40-45, use 38 jet. For fuel pressure 55-60, use 36 jet. http://www.nitrousexpress.com/oldweb...mjetting09.pdf
