Which wire out of ECM is 5 volts at WOT ?
What wire at ecm is 5 volts when TPS is full throttle ? The wire I thought it was is RED 24, TP sensor signal,a dark blue wire,but its only 4" long and goes nowhere,and has no signal there,i do see 5 volts at the sensor dark blue wire,and I see 0-100% on the scanner.So what wire do I need to tap into at the ecm to see WOT as its inside my car along with the nitrous wiring ? And does it hurt anything for RED 24 TP sensor signal to go nowhere ? Thanks
