N2O 200 shot budget setup
Old 04-28-2016, 11:23 AM
5.7stroker's Avatar
Default N2O 200 shot budget setup
Looking to add a 200 shot. "Budget" build safe setup:
N2O outlet Fast 92mm plate kit with 10 lb bottle - $800
N2O outlet stage 2 accessory kit - $400
N2O outlet remote bottle opener 00-66000 - $259
N2O fbody bottle mounting bracket - $60
42 lb. Bosch Fuel Injectors 165-FIC42LS1B - $310
LNC 2000 - $275
NOS progressive controller (02-15974NOS) - $275
Racetronix 255 pump and hotwire kit (FPA-001B & FPWK-017W) - $219
N2O outlet F-Body Plastic Fuse Panel Area Dedicated Fuel System - $600
Nitrous cig lighter panel switch - $69
2 1/16 fuel and nitrous pressure gauges - $200
$3467
And then there's the tuning....
Thank goodness for ls1tech classifieds where I was able to get most of this stuff at discounted pricing....this way I won't blow the welds off the intake and have to tear apart the block like a mad scientist to replace the piston rings...
Step up to a BIG BOY 300 lb shot and more NA power and might as well get Lonnies RX-F99-GSS340-DP-FS-PKG - (Double pumper, -8 Supply & -6 Return lines, fuel rails, regulator, filter, & all fittings needed to connect to double pumper sending unit.) - $1625
Old 04-28-2016, 12:14 PM
brandon@nitrousoutlet's Avatar
That's a good looking list! Let us know if we can be of any help.
Old 04-28-2016, 02:13 PM
5.7stroker's Avatar
You guys have been great! Currently working with Houston on a quote for various parts.
Old 04-28-2016, 08:22 PM
ATwelveSec02Z28's Avatar
Just throwing it out there.... But you're $3k deep, why not go with the LPE NCC002 over the NOS controller....
Using the system with nitrous and fuel pressure, you get datalogging, low fuel pressure safety and can even control the bottle heater by pressure....
$600 more is a lot of money but what you get out of it is worth every penny
Quick Reply: N2O 200 shot budget setup
