LNC 2000 and NOS mini progressive wiring look correct?
Old 05-04-2016, 07:40 PM
5.7stroker's Avatar
Default LNC 2000 and NOS mini progressive wiring look correct?
Edit: updated wiring diagram
I'm using DV32V distribution blocks and a Bus Bar for multiple ground connections.
DC32V 8 Way Circuit Car Boat Automotive AUTO ATC ATO Blade Fuse Box Block Holder - Electrical Fuse Holders - Amazon.com DC32V 8 Way Circuit Car Boat Automotive AUTO ATC ATO Blade Fuse Box Block Holder - Electrical Fuse Holders - Amazon.com
DC32V 6 Way Terminals Circuit Car Auto Blade Fuse Box Block Holder ATC ATO - Electrical Fuse Holders - Amazon.com DC32V 6 Way Terminals Circuit Car Auto Blade Fuse Box Block Holder ATC ATO - Electrical Fuse Holders - Amazon.com
Amazon.com : Blue Sea Systems BusBars (100A-250A) : Sports & Outdoors Amazon.com : Blue Sea Systems BusBars (100A-250A) : Sports & Outdoors
Bigger image: http://s234.photobucket.com/user/dpa...68lzo.png.html
Old 05-05-2016, 09:12 AM
Nitro Dave's Nitrous Outlet's Avatar
Attached is the wiring diagram that we use. If you have any questions feel free to contact me at 254-848-4300 ext 111 or email me at Matt@NitrousOutlet.com and ill be happy to answer them! -Matt
Old 05-06-2016, 01:05 PM
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default LNC activation via arming switch
Matt,
A couple of things we noticed in that diagram:
I would make sure users are careful about the source of the 12 volt switched power - the purge solenoid and the bottle opener are drawing current from that 12 volt switched power source in that diagram. Many vehicle interior switched source power locations likely shouldn't be used to draw that much current. Using relays to enable the purge solenoid and the remote bottle opener would allow them to get current from another source and you wouldn't have to have high current going all the way to the switch panel.
Also it looks like the way this is wired the LNC-2000 timing retard will be active (ie taking out timing) when ever the arming switch to the nitrous controller is active, regardless of if have nitrous actually spraying.
Since that controller has programmable outputs why not use one of the programmable outputs to activate the LNC-2000 timing retard only when the nitrous is actually spraying? I believe the outputs are ground type so you would have to use a relay to convert the output to a +12 volt output to enable the LNC-2000 timing retard.
Old 05-06-2016, 02:35 PM
brandon@nitrousoutlet's Avatar
Hey Jason,
We recommend this wiring because the only way to ensure that the lnc-2000 is working is to feel the timing and power come out of the car. If for some reason the box doesn't work, there's a wiring issue, faulty relay etc., I'd rather find out by the car feeling sluggish rather than blow my intake off. It's just a precautionary measure. While these boxes have an excellent track record for reliability, we typically err on the side of caution. However, this doesn't work well for race car applications because it can be hard to get up on the 2-step with a bunch of timing yanked out. If our customer needs instruction on wiring the mini to the LNC, we can provide that as well.
Old 05-06-2016, 02:54 PM
5.7stroker's Avatar
Wiring diagram modified to include relay between purge and switch.
Can I use a 6 way fused distribution block with 6 wires leading to each of the 6 switches, and just wire the keyed 12V wire coming from the factory fuse box to the main terminal on the fused distribution block or will that over load it?
Old 05-06-2016, 04:58 PM
jblankenship's Avatar
I agree with using the output to trigger pulling timing. There is et to be had by delaying the timing being pulled even .02 or so. This lets the motor rev easier until the nitrous actually reaches the motor. It's also helpful if your delaying the nitrous for some reason you can delay the timing being pulled.
As far as testing the box that's easy. The outputs are ground triggers. Tap another wire on the circuit. I have a covered female spade that tuck under the edge of the console. When I get to the track I arm the nitrous and touch the spade on a bolt that grounds, if the motor stumbles I know it's pulling timing. Now, I have an iat tricker box ,but it's the same idea.
Old 05-06-2016, 11:53 PM
5.7stroker's Avatar
Even if launching off the nitrous, use the programmable trigger?
Old 05-08-2016, 09:21 PM
Yes, even launching of the nitrous I delay pulling the timing .2 seconds.
Old 05-17-2016, 08:51 PM
5.7stroker's Avatar
Got it all hooked up. Everything is working. Will post pics when I get it all back together.
Quick Reply: LNC 2000 and NOS mini progressive wiring look correct?
