Stupid question just out of curiosity
I was looking a friend of mines 03 gt with a dry kit on it. His kit has a single solinoid with a single hose tapped in the cold air intake about 3in in front of the throttle body. (This is suppose to be considered a dry kit for mustangs?) He has ran a 100 shot for quite sometime with no problems. I was just curious what would happen if you did the 05177 kit to the LS1 like this. Just use a single line with a nozzle in front of the TB, & Use the other noid for a purge? Would this work? IM JUST ASKING OUT OF CURIOSITY I have also seen a 91 or 90 iroc with the same setup..
Originally Posted by Nitro Dave's Performance
One the fords and the LT1s the fuel is added by a nitrous management unit.It puts pressure on the fuel reglater causing it to raise the fuel pressure.On a LS1 the maff sensor adds the needed fuel.
