timing tuner ?????????
Ok the direction are at best criptic i for the life of me figure them out. and i have done a surch . the direction came with a great direction sheet for setting max rpm for nitrous turn off. i wish the did the same for min turn on setting set up can any help with that and is ther a web page the breaks the direction down even more.
thanks
thanks
I am looking at the chart I think i must be missing a page. Any way Ok the rpm turn on number is 5 for 3000 but how do go about setting it i mean whare do you set spark base what order are mode switches set in . also who makes this thing maybe there is better direction on there website.
you just put the rpm **** at number 3.. The only one that requires programing is the turn off point, all the others are set directly from the *****. If you go to speed inc's website they have the pdf doc where they sell the tuner, its for the older version but everything is the same except the old version doesnt have the programmable upper rpm turn off limit.
