super stealth nitrous kit?
I remember seeing a picture of a dry nitrous kit that had a very very small NOS tank, about the size of an average paintball co2 tank. Anyone know what I am talking about and where I can get this, or should I just buy all the neccessary noids, lines, jets, ect and hook it up to a small tank and hide it? I wanna run a small 50-75 dry shot just for emergencies
I believe you are talking about NOS's "sneaky pete" system its a very small shot.I'm not even sure if it will spray a 50 shot it runs off of a 9volt battery.NX makes a similiar kit called the "incognito" thats a little different these kits are mostly used by someone for that little extra to win a race.Contant Nitro Dave he can help you with all your needs and questions
BTLFEDSS
BTLFEDSS
Originally Posted by 5.8litrels1eater
There's lots of place to hide tanks, especially if you have a 5# bike nitrous bottle. There's lots to hiding a kit, here is a decent job of hiding the noids.....
yeah thats REALLY nice, I am saving those pictures for future reference. I might go with the NX incognito kit but is it safe to use this kit on a TR224 cam??
8 second mod
buy a real kit with a 5# bottle, and hid it, you wont even feel a 25 shot, a 50 is almost non existing, a 100 is when you can tell you have the spray.
id do it right with a dry and hide it, never mind the sneeky pete thing. those are good for motorcycles tho
EDIT: The bottle goes where you spare tire would, but you take out the speaker so you can open the bottle through the speaker hole.
Found this on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...category=33740
might be what you're looking for?
I'd be leary of components listed in that for anything OVER the 50 shot reccomended. In fact, I would never even add just a 50 shot on an LS1. Also, what about bottle pressure?? Do they make heaters small enough??? I wouldn't want to run nitrous at 600 psi.
1.4 lb. bottle (whats like, 4-5 shots on a 50 shot??? 1-2 on a 130 shot??)
solenoid (only one noid, problems with noids sticking and continuing to spray)
fill fitting
polyline (I'm not to fond of this stuff)
jets (biggest is around 50 HP) (I'm pretty sure they rate flywheel, so like 30rwhp)
arm switch
throttle switch
pushbutton.
You could get a REAL kit for real close to that price if you looked around.
fill fitting
arm switch
throttle switch
pushbutton.
SSU Moderator
whats the point of hiding a kit if you are gonna put the bottle in the spare tire compartment.
do it up like that lower airbox above (or something else...there are MANY places and ways to hide solenoids) and use a 2-5lb bottle. You'll find a place to put it. They're small. No need for a heater. Use the small NOS solenoids (powershot?) and -3 line and don't bother w/ jets. You probably won't get it above 100hp. Oh, and two solenoids are NOT necessary. its a precaution if a sol. sticks open....which (hopefully) rarely ever happens. If it does...just stay in it until that little bottle runs out
Here is our cheater system...This is a wet system..
Here is a pic of Jamnuts Halo install.This is our Dry Halo System.
Also here is a link that Ryan put up on our Halo kit.Watch his Video.
https://ls1tech.com/forums/showthrea...t=Halo+Nitrous
Dave
Dave
Originally Posted by pushinfreight
form the first pics it looks like you are spraying before the filter. Will this have an effect on what on delivery of the no2?
