Direct port help again pic inside
Old 04-06-2005, 12:09 PM
Z284U2TRY's Avatar
Default Direct port help again pic inside
This is my problem I need a large T fitting anyone have any idea how to connect the 2 fuel noids with out moving them? I wanted to run one 6an fuel line and t off at the noids. Also if anyone knows a good place to buy fittings without cost an arm and leg that would be great also.
Old 04-06-2005, 02:15 PM
860 Performance's Avatar
Ditch the straight 1/8"npt to 4AN's and replace them with 90deg versions. Then buy a NX high flow Y adapter. It has an inlet of 6AN and two 4AN outlets. Then two short braided lines.
This is not cheap but would be a sweet set-up. Check with Nitro Dave, I'd bet he has everything in stock.
Old 04-06-2005, 03:11 PM
Z284U2TRY's Avatar
The pieces are 1/4x6an I found a female t adapter at www.pitstopusa.com I am going to try it and see if its long enough.
