!MAF, will nitrous still work for me
I have had my car tuned without my MAF, I'm getting ready to put a piece of pipe in its place.Will I still be able to use a wet/dry kit without it, or does it play a role in the spraying process?
You won't be able to run a dry kit, dry kits use the MAF to adjust the fuel and compensate for nitrous. Im asumming you should have no problem running a wet kit or DP, someone correct me if i'm wrong.
Someone can chime in here soon im sure.
Mike
Originally Posted by Slow Z28
aren't some DFI(speed density) systems running a dry fogger system?
I thought reading in V6 Bird's post he was mentioning running a dry kit on a speed density tune
Originally Posted by V6 Bird
Yes some are doing that...I havent gotten that familiar with the SD stuff yet...Im in need of some $$ to buy the HP tuners setup right now
Chris
