SES light on and not sparyin all the time?
Ok so i went to the track and wanted to spary a 75 to get used to it. I have a BMN window switch with 1st gear lockout. I have it turnin on at 3k and off at 5800, So the first run bottle pressure was good but it never sprayed when i ran. So i took 1st gear lock out off and the same thing didnt spray. So third run i t worked fine and i went 12.5 @ 114... dotn no if that good fir 75 shot?. Then i tried again with first gear lock out on didnt work...... n e way it was on and off all night, when the first gear lock out was on it never worked, but yet it worked on the street a day before. Also at the end of the night my SES light came on what should i check first? Car seems to run fine. Thanks for all your time
i would check all the wiring and hook ups for the 1st gear lock out...it may have worked that first day but sometimes things can get worked loose and messed up especially if you just installed it
