300 shot on 408??
Old 06-16-2005, 08:49 AM
necrocannibal's Avatar
Default 300 shot on 408??
Ok Im dynoing Saturday and want to spray a 300 shot on the dyno. I have a stand alone fuel system so I wont run out of fuel. I am using a TNT Power Ring but only using 1 nozzle. David at TNT said that one nozzle will flow that much. What I have a question about is the car isnt tuned for that big of a shot. Im spraying a 200 shot now and having no issues at all but will a 300 shot be an issue?
Old 06-16-2005, 08:54 AM
Nitro Dave's Nitrous Outlet's Avatar
You will more than likely need to pull some more timing for the 300 shot.
Old 06-16-2005, 10:48 AM
12 Second Truck Club
Magic Chicken's Avatar
one nozzle flowing 300? that sounds like a pretty bad *** nozzle.
Old 06-16-2005, 10:50 AM
v8maro's Avatar
What kind/brand of rings do you have?
Old 06-16-2005, 10:57 AM
he said TNT Power Ring in his post.
Old 06-16-2005, 12:12 PM
Restricted User
CAT3's Avatar
Since he is using the TNT PR, I would assume he's using TNTs 150 jet chart for that 300 shot
Yes, helluva amount of flow for one to atomize very well, but then again, maybe not. Pull a lil timing, ~4* and regap plugs, or swap to step colder depending on your current plugs. Good luck and post up how she does.
Old 06-16-2005, 01:27 PM
860 Performance's Avatar
4* for a 300 shot? That seems a little low. I have a completely different engine set-up so its not apples to apples, but I pull 10* for my 300 shot.
Old 06-16-2005, 01:40 PM
DONAIMIAN's Avatar
I think he meant 4 more degree on top of what hes already pulled for the 200 shot.
Old 06-16-2005, 02:42 PM
ahhhh
Old 06-16-2005, 03:36 PM
Josh's Avatar
I think he's asking about piston rings, but I could be wrong.
I tend to be overly-cautious, but you're mighty brave to be spraying 300 HP via the intake through a single nozzle.
Josh
Old 06-16-2005, 04:26 PM
Thanks for the replies so far. I dont know what kind of rings are in the motor, it was buitl by someone and I didnt ask him what he used but he knew I was going to be spraying the house down with it.
Is there going to be a problem spraying a 300 shot through a single nozzle? David at TNT said it would flow that. Also are there going to be any issues with the intake? I might not do if it is kind of iffy to be ok.
The jets I would be using would be 89 nitrous and 71 fuel. I have a stand alone fuel system running 10 psi in which Im running 116 octane fuel through. Thats why the fuel jet is so big.
Old 06-16-2005, 10:01 PM
Restricted User
CAT3's Avatar
Yes, thankx stang killer, I did mean pull 4* from the current tune. If the engine is built, how much nitruos was it built for? Using standard "off the shelf" pistons, rings & rods, 300 is about max you'll want to venture to. I would approach this in 200, then 250 and if its all good, then 300. My shortblock was built for daily doses of 200shots, but I will be blasting 300 through the intake and DUAL Shark Nozzles and the HPE Ring. Similar but I really prefer the atomization of a single nozzle going no more then 200shots. I know the neighbor might get away with it, but will you?
Old 06-17-2005, 12:10 AM
DONAIMIAN's Avatar
I agree with CAT3, go with a dual nozzel set up. If not the NX maf kit since its gona be blown through the intake.
Old 06-17-2005, 07:37 AM
The motor has been taking the 200 shot with no problems what so ever. Everything runs fine before during and after spraying it. The engine builder told me that the motor should have no issues taking a 400 shot but he wasnt sure about anything past that.
Old 06-17-2005, 10:16 AM
Shorty Director
VINCE's Avatar
Wow!!! Must be nice to be able to spray so much
Old 06-17-2005, 10:41 AM
Mike K.'s Avatar
300 shot is approaching the breaking point, just be careful
Old 06-17-2005, 01:23 PM
next's Avatar
A 300 shot seems huge when you're talking single nozzle, although I've heard of 250 with just one. Also, if you up the HP in stages you could check all the plugs and make sure they are reading the same just to make sure you're getting equal distribution.
I'd ask for a build sheet so I knew exactly what was in the motor.
Let us know the results.
Old 06-17-2005, 01:36 PM
badass 2002 z28's Avatar
regular moly rings will easily hold a 250shot..anything more and you want to use nitrous rings..like hell fire rings. I'd find out what you're running beforehand.
Old 06-17-2005, 04:28 PM
Elite_Hot_Rod's Avatar
I've been running a 300 shot on my forged 408 for a long time. The only thing you need to watch are the pistons and valves. Your pistons may not be rated to make that kind of power and the valves may mushroom from the pressure. What do you make on motor?
Old 06-17-2005, 08:08 PM
2toneblown's Avatar
The fuel for that kind of shot will not atimize in the intake very good. I leaned out multiple cylinders with the NX 300 SHO nozzle. The composite intake is not a good idea for that much bottle to go through it. I tuliped multiple valves from the heat and cylinder pressure. Put a direct port or something on it.
