leaks
leaks
should my lines leak at all near my noids. its not much barely noticeable but if i put my ear right up close i can hear it, is this normal, i have the fitting on real tight
You did use RED (high strenth) liquid locktite on the 1/8 npt threads didn't you. Loctite does a real good job of sealing and preventing fittings from coming loose. Use just enough to seal threads.
