FPSS Location
FPSS Location
I have a NX FPSS and it says to install it directy into the N20 solenoid. I was wondering if I could just mount in on the end of my fuel rail as space is a little limited around the solenoids. Is this cool or bad idea?
Originally Posted by Robert56
I have mine there, and have used that spot before. I have a NX install manual and it says to mount near fuel pump, or at least before regulator. Now I don't know what kit/car this manual is for, but remember it saying this.
Robert
Robert
i dont know why you wouldnt want it as close to the fuel noid as possible to assure adequate flow throughout the system instead of just by the pump or before the regulator thats like getting false readings. put it right at the fuel rail is the norm.
Robert
Robert
Originally Posted by cantdrv65
A pressure safety switch before the regulator? That manual needs some serious revision...what little value a FPSS may hold would be defeated, and it would surely be absolutely worthless in that configuration....
"The best location for fpss is at the outlet side of the of the fuel pump...This location will allow instantaneous n2o sys shutdown is case of fuel pump failure. The next best location would be on the high-press side of the fuel press regulator...
Robert
On a low press system NX states:
Robert
Robert
Line pressure from the fuel pump to the regulator would have to bleed down before an "instantaneous shutdown" would occur, that would occur before you saw a dip in the low pressure side of the regulator....Going by that theory that would be a good location in a carb application. But no matter a low pressure system is not applicable in this case anyway.
Robert
