Holley Blue pump for stand alone single fogger
110 gph
14 psi
Would a stand alone fuel system work with this pump? Gonna be running a single 150 shot off a shark nozzle NX kit. Has any one done a LP shark nozzle?
Thanks.
14 psi
Thanks.
If I remember correctly the N2O is a .62 and the fuel is a .48 for 10psi tune. I have run a 150 shot no problem and also a 200 shot. However, I was melting the rear 2 plugs on the 250 hit on a less than 1/8 mile pass. Just atch your fuel distribution and you will be fine. BTW I am running 10-1 A/F ratio on all of the shots. I even lowered the fuel pressure to 7 psi and only got it to 10.4-1 A/F so the jetting above is rich (no improvement in ET or mph either). The 200 is an 82 n2O and a .62 fuel. The 100 jetting is .47 N2O and .38 fuel.
As has been stated, you can use it but I have no idea what the jets would be.
The pills you'll get with your NX kit are gonna be for a EFI car running 40+PSI.
Better choice would be an Aeromotive. You can set it to run with the standard FI jets, but more importantly, you'll have lots of room to grow
Jon
Jon
Originally Posted by Noyzee
the setting on psi will depend on tuneup.
id start high, and flow it till the plugs/tuneup look good.
Id' rather find that out. Set it a little bigger then that then tune it on the dyno from there.
Thanks for the help guys.
