TR6 affecting performance?
Spark plugs are more function than performance. They will not negatively affect your power. If you retarded timing, to go along with an XX/X shot of nitrous, THEN when not spraying you will see/feel a difference at the dyno/seat of the pants.
Restricted User
And if the gap isnt right, or too cold a plug the function part is fucked thus your performance will suffer.
You should be fine at .035" gap and TR6 NA, but depending on shot size, might open it up to .038-.040". Try and see if the burn is clean and timed correctly.
Charlie
