after nitrous passes (problem)
Old 09-29-2005, 03:28 PM
dubrado's Avatar
Default after nitrous passes (problem)
I'll turn off the car and go to turn it back on after parking and it'll have a hard time starting and want to stall out...so I either give it gas or try again, and it'll run fine afterwards....
This only occurs after I turn off the car after a nitrous pass and then turn it back on later.
any ideas?
Old 09-29-2005, 07:56 PM
Matt@HSW's Avatar
Is this a wet kit? Do you know what your A/F is?
Old 09-29-2005, 08:53 PM
dubrado's Avatar
it is wet kit, but dont' know my a/f
need to dyno and see
Old 10-01-2005, 12:27 PM
dubrado's Avatar
anyone else?
Old 10-01-2005, 04:34 PM
mrr23's Avatar
one thought could be is the fuel solenoid not closing completely after the run. thus flooding the engine. once FP is zero, the solenoid then closes. remote shot on that one.
Old 10-01-2005, 04:50 PM
NitrousDirect's Avatar
I was thinking it sounds like a flooded condition, you may be spraying too much fuel or have some odd thing where your fuel solenoid is not closing at the same time
Old 10-03-2005, 12:22 AM
Nitro Dave's Nitrous Outlet's Avatar
Like mrr23 said.It copuld be your fuel solenoid not closing all the way.
Test the solenoids and check them out.Then get back to me.
Dave
Old 10-03-2005, 05:19 PM
2000TransAm24's Avatar
I have this same problem even when I'm not spraying. I thought maybe it was just heat soak. Also my A/F is not rich.
