New product....
New product....
Ok guys we have a new windowswitch.This unit has been undertesting for about a month now.
Ok here is the build on it.
It is a fully digital unit.
It is water tight so you can mount it anywhere.
Features...
This unit has two different windowswitch selections within one unit.Each setting offers a selection to chose a lock out in any gear.This unit also has a built in TPS unit.
This unit sells for 129.99.
Here is a pick of the test model with it sitting on the dash of the test vehicle.The unit is not much for looks.However the digital screen and case are very heavy duty.
Features...
Thanks for posting Dave.
When you say 2 window switch selections in 1 unit are you saying there are 2 sets of settings. For example you set an on rpm and a off rpm as 1 selection and you can choose another selection of a different on & off rpms then you can only use 1 or the other at a time or they can be used both at the same time such as 1 set fot turning the spray on & off and the other set for controling another function?
Can you post instructions and how does the lock out feature work?
very interested so this takes over the window switch and includes lock out nice. how hard is it to install? can you lock out more then one gear like 1st and 2nd gear and how hard is it to change can it be done on a fly? How is the lock out activated?
Thanks
Thanks
Thanks
Thanks
Robert
i have the new progressive controller from fjo that i bought from you Dave, i was wondering how the 1st gear lockout works if you have say a th400 transmission with nothing telling the computer when it's shifting gears etc?
Restricted User
Screw! Damn it Dave, I can't believe you were hiding this from me! It just so happens to be I need something like this. Ugh... Ditto on posting the instructions, or email..
cat3n4@gmail.com
cat3n4@gmail.com
if u read more carefully it says "Each setting offers a selection to chose a lock out in any gear", so it's not just 1 gear or 1st gear...to me it seems that u'll be able to pick a gear u want 1 stage of nitrous to kick on, choose the RPM on and off and ALSO choose what gear ur 2nd stage comes on and of course what RPM on and off...very nice, glad I bought this forged shortblock...2 stage dry here I come :-D. So, if I can word this correctly u can spray 1st and 2nd with ur 1st stage then spray both in 3rd and 4th and also choose SEPRATELY what RPM u want them on and off...am I on the right track Dave?
Robert
Originally Posted by Nitro Dave's Nitrous Outlet
Ok guys..
Yes this is a dual windows witch.Meaning you can controll two stages.Eacg windows witch has an option of locking out the spray in any gear.1st gear,2nd gear,3rd gear,4gear...
You are one the right track.
Dave
Dave
Any chance that you guys could build a dual stage controller just like this but with a timing control like the timing tuner??
Tell me where to send it.
Restricted User
Dave, you got this in stock? PM a price shipped will you? You should have my address in the rolodex next to the donut box and phone! 96707. Might have to order this tomorrow if its in stock and ready to ship out! Would like to see the instructions or wiring diagram.
I'm gathering way to many electronical gadgets for the car...whats one more right?
Charlie
Charlie
