A little Help
A little Help
Yes i finally decided to go with the TNT F1 Kit and buy a window switch with it..will i be fine for now if i use it, i dont have enough money to buy the fuel and N20 gauges and should i invest in any other vital saftey equipment
The most important safety device is the window switch.So atleast you have that covered.In order to get the system to opperate at its full potential I suggest a bottle heater, purge,and fuel pressure safety switch.The kit comes standard with a blow off fitting,blow down tube and pressure gauge.You can always *** the extra parts later but deffintly get the window switch.
Dave
Dave
Originally Posted by DarknessArises
how vital would the bottle heater be..also its getting cold in New jersey and winter is comming
i see, aight ill be sure to get it as soon as i got the money but i read somewhere else that you need a WOT switch to accompany the window switch or something like that
do you have to have it or is it just highly recommended
It's a $13 dollar part. Your motor is a $4000 part. You make the call on whether or not you NEED IT, I say you absolutely 100% NEED IT.
