regulator upgrade?
Old 11-16-2005, 10:05 AM
1fastz28nx's Avatar
Default regulator upgrade?
Does anyone know if it is necessary to upgrade the fuel press. regulator to run 150 shot, i already went to a walbro intank pump. Its a stock motor now, but heads and cam are coming soon.
Old 11-16-2005, 10:17 AM
NXJeremy's Avatar
The only reason I can see where upgrading the regulator would be useful is if you wanted to be able to make small incremental adjustments to the nitrous-to-fuel ratio. Otherwise, there really isn't a need to, you can just change the fuel jet to adjust the nitrous-to-fuel ratio.
Old 11-16-2005, 10:18 AM
1fastz28nx's Avatar
alrite, thanks man
