Cheater Cam Good for the spray?
The cam specs are: 214/230 .601/.578 117 LSA they will be with the AFR 205 cylinder heads, and a F.A.S.T. 78mm or 90mm (havent decided yet, what do you think?) I would like to go Direct Port with this set up maybe a 125 to 200 shot. Does this sound like a good mix? any comments will help--Andrew
It will be either TSP duals w/ sweet thunder or a custom X-pipe with moroso spiral flows. It will be a weekend car, but will see a day or two at the office. do you think i should stay with a 78mm or go with the 90mm intake?---Andrew
It would work good....any cammed Ls1 likes nitrous
if your getting a fast do the 90mm.
Keep your exhaust it would work fine. Get a cutout to maximize power when you spray it.
The setup your talking about would work out very nice IMO.
That cam will be fine, even for a large shot.
The FAST 90 will require a new TB, making the choice more expensive, but is probably the best way to go for the setup you are describing.
