max rwhp from small nx noid
Originally Posted by cbrtrx
i cant seem to get more then 100rwhp on mine, ive been looking into reasons why, i think im gonna test other brand noids to see if theres any differance
You should definately get more than 100. What bottle pressure are you using?
You may want to check the small line after the noid. I have had tons of those fial internally. Take it off and blow thru it and see if its backed up. Same with the -4 main feed line. Also if you have a filter...or especially one of those cheesy littel filter screens...pull that apart and check it.
If you want I can make a solid line from the noid to the nozzle from aluminum tubeing. That will flow alot and eliminate that possibility.
What size jet do you have in for your 100 hp increase? Whats thew largest jet you have tried?
If you want an NX larger noid hit me up.
