Tach wire and window switch.
1 Post
Originally Posted by smokin2002
I have my window switch mounted in the car. what is the easiest way to get hooked up to the tach wire from inside the car?? wire color??
Assuming your car is an 02 I am pretty sure it's the #11 wire on the PCM. I know it is white but there are several white wires coming out of it so make sure you have the correct one. Also, you could probably run the wire through the hole in the firewall where all the PCM wires come through.
yes the car is an 02.. if someone could verify if its no. 10 or 11 that would be great!!! Ill have everything wired up once that wire finds its home. The Digi switch is mounted under my arm rest so ill shoot the wire up through the gromet which already has no2 line, 2 ga trunk battery wire, fan switch, and,and, and,
I think it came out pretty good though.
1 Post
Originally Posted by WS6HUMMER
Yes it's the #10 pin, White wire on the Red PCM plug.
Originally Posted by Macon
There is no connection on the (other plug) blue plug at 10 so you can't hardly mess up!! There are several white wires as stated.
1 Post
I was quoting Matthew Harlan's instructions for a shift light, wasnt looking @ the PCM plugs at the time. Thanks though for the LS1 trivia answer though.
Originally Posted by bad6as
well if i have a shift light all ready spliced in the tach wire, could i slpice in to the shift lights wire or threw the pcm again?
