Direct port fuel pressure regulator???
Old 01-18-2006, 09:40 AM
Z284U2TRY's Avatar
Default Direct port fuel pressure regulator???
Just wondering what kind of regulator and pump combo everyone is using for a low pressure fuel system. Also would like to know if the majority of people are using a return style or returnless reg.
James
Old 01-18-2006, 10:59 AM
Tony Shepherd's Avatar
You can buy a full dedicated system from Nitro Daves Nitrous Outlet. Comes with the fuel cel, pump, regulator, and fittings. Has a return system built in.
As you can see in the pic.....the system I bought bolts directly into the battery location using the battery hold down.
Attached Thumbnails Direct port fuel pressure regulator???-dcp_0849-medium-.jpg
Old 01-18-2006, 11:11 AM
NXJeremy's Avatar
Tony already suggested what I was going to, but also I would suggest that what ever you use make sure that it's a quality product like Aeromotive, Magnafuel, etc.....nothing worse than having a dedicated fuel system fail to operate properly. Plus, the higher quality regulators and pumps are easily rebuildable for routine maintanance.
Old 01-18-2006, 11:25 AM
Z284U2TRY's Avatar
Thanks for the help guys already have everything just looking at getting a better regulator and wanted to see what most guys are running.
Old 01-18-2006, 11:35 AM
Closed ex-Sponsor Account
NXRICKY's Avatar
For the REG, depends on a return system or dead head. If return go with an aeromotive, if dead head use the old holley blue reg.
Ricky
Old 01-18-2006, 12:44 PM
383LQ4SS's Avatar
I used a Mollory EFI regulator and it worked very well on my home made one.
The NitroDave setup I have used on a few different cars and it works great as well. I think he puts an Aeromotive regulator on his.
