Biggest shot on stock motor
I'm looking at this kit (Harris Speed Works Sudden Impact Big Hit Dual Nozzle Wet Kit). Just wondering how big you can go. I'll be getting a new in-tank fuel pump of course.
http://www.harrisspeedworks.com/shop...cat=364&page=1
1 Post
Most people will say 150 shot, some have done a 200 progressive shot on the stock block successfully
my opinion on the 200 shot is that there is no room for any error, and your block is on borrowed time
1 Post
Originally Posted by sleeperstyle
why is that?
i do think it could be done safetly, but it would take a lot of experience to design and monitor a safe 200shot/stock motor system that would last long term.
key word=long term.
so im not saying its impossible, im just saying i wouldnt do it myself
Well heres my .02 It seems that when the manfuacturer rates these kits at a 150 shot, you wont get that gain at the wheels. I have a 150 shot and I actually see a gain of around 130Hp at the wheels, so a 200 shot rated may only get you 170Hp, which on a otherwise stock motor seems safe to me, provided the fuel system is up to par, colder plugs and window switch are used. A tune is also good to get. The stock block can handle a good deal of HP. You just dont want to get any detonation while using a shot that high or else it goes boom.
1 Post
Originally Posted by camaroextra
very true. there are kits that actually dyno higher! depends what brand.
Originally Posted by MyTA99
Well whats the diff between
300 HP with 150 coming from cam, heads, headers with 150 shot
Vs.
300 HP coming from a 300 shot
Vs.
1 Post
Are you thinking of nitrous lean spike?? I dont have a TQ spike, its high all through the rpm range.
Originally Posted by oange ss
all juice motor wont last as long unless you use a progressive controller
Anyone runig a 300 would probably use for track only and then have the 100-150 for the street.
I mean I'm a Nitrous Newbie but wouldn't a shot be safe as long as your fuel system is upto it.
if you want to run a big shot then i would consider making it either a dual stage or using a progressive controller but either way i would definetly look at hsw's stand alone fuel system as another safty precaution
Also what happens with the wet kit when you run out of juice and your just spraying extra fuel.
