Right RPM for window switch with 3200 stall
trial and error- at the track for my 11.00 run i had it hit at 3900 rpms, and i launch at 3800. on the street i usually have it hit at 42-4300 rpms, which netted me 11.1's at the track.
street tires= not gonna hook anyway, but 4000 is probably a good starting point and work your way closer to the stall speed as traction/drivetrain permits
if you spray it out of the hole (ie. below your stall speed) on sticky tires you are asking to break something.
