Need some help on getting a few things.
I have a msd digital window switch with my nitrous kit. im about to spray 200 shot i dont want the rear end to go out.
Now im about to buy thi sproduct here http://www.harrisspeedworks.com/shop...3&cat=0&page=1 and i also wanted to know if i should get a MSD ignition 6AL and a blaster coil. Or do i even need the coil? or should i just get a mallory 685 and get rid of my digital wondow switch since this one already has one in it?
Reason im getting the controller is so that i can spray 100 shot off the line then the full 200 after 4.2k rpms all the way to 5800 rpms (where my end rpm is)
Also i do want to retard timing for n/a runs and nitrous runs. Because when i race and want to turn the pregressive controller down alot of percentage % (25% start and 50% end which would be 50 shot starting and 100 shot ending) I would also have to add some more timing hence the timing would be pulled for a 200 shot.
Or would i even need to have a tune to pull timing if im get the MSD 6AL and a Timing retard box? SInce the timing retard box has an adjustable ****.
Please let me know if this makes any since to you.
Randy
Randy
The mallory 685 has been pretty popular with our LT1/LT4 customers since it has the window switch along a timing retard feature in a "all in one box". In most cases I suggest the mallory box, and along with a progressive controller you'll have a full featured nitrous controller.
Matt
Matt
No, you could still use it instead of the intergrated one. I'm pretty sure the timing retard function is seperate from the window switch on the mallory, but I would suggest double checking with mallory that you don't have to use the window switch inside the mallory 685 in order to use the timing retard function.
Matt
Matt
