NO Digital dual window switch
a few wiring questions before mine arrives and i install it.
1).this piece should be compatible with my fpss right?
2).*User configurable for rising or falling TPS signal
i hear you get a better signal through the falling pink wire is this true?
3).do they make plug and play pieces so i dont have to cut into my stock wiring for my tps signal and tach signal? im not a big fan of cutting into the stock stuff and was talking to a guy yesterday and he said he had a plug and play piece. maybe ill stop my his shop tomorrow and see but want to confirm this first.
4).anyone know what each color wire is at the tps?
-blue = rising
-pink = falling.....
i also got some wiring instructions that were posted before that are pretty close but dont tell me any answers for the questons above
http://img143.imageshack.us/img143/9...wswitch6xa.jpg
-blue = rising
Closed ex-Sponsor Account
By the drawing the WOT will not be used by the Vette. 02 go with rising no problems there. 05-06 have the issues. FPSS just use enbetween the control grounding wires from your switch to the relay.
Ricky
Ricky
ok i edited the image to what mine looks like. FPS2 = fuel pressure safety switch. i also removed the orange cause im using single stage and didnt want to confuse anyone with the extra wire. i also removed the toggle ground as i didnt use the lite up toggle as the ones with the kit idont like and the ones i have are on/off(no light) there is also fuses between the battery-relay & battery-toggle switch.
does everything look alright? i truely hate wiring so if you see a problem let me know cause i dont trust my wiring work
Originally Posted by NXRICKY
looks good.
Ricky
Ricky
if its right all i need to wire is the tach & TPS and program it. i still have to wait till the 11th for plug wires though
