What head gasket and bolts with spray?
Im spraying a 150 and want to move to a 200 wet shot. Im also intalling tsp ls6 heads and fast 90/90 what head gasket and head bolts or studs should i use to support the spray. also are rod bolts nessacary?
Restricted User
I havent really pushed the stock stuff too much, did some runs on 220, and loads of 175 with stock rod bolts, never had an issue. I would think if nothing else it would be a little insurance. As for the gaskets, I am running Cometic .040" and ARP Studs, simply because it was a new engine, but doing HC swap, I'd recommend them too. Overkill? Maybe, better to have it and not need it
1 Post
Studs ARP 12 points...i've used Cometic MLS. Use GM MLS right now. The MLS, in my case , because two different metals are being bolted together. Aluminum heads and Iron Block.
