Do you think this is resonable?
I want to get a nitrous kit completly installed and everything for $1,000 or less, it would be a 75-100 wet shot and i would need it installed becuase i can't do something like this myself. I want is to be as safe as possible and upgrade the fuel pump, and would bigger injectors help also?
I also want a purge, but it come come later if it will break my 1K mark.
Just curious if this is a resonable price, or if it would cost more
thanks,
Nick
I'm also starting to price all this materials, this is what i was gona start with
http://www.dynotunenitrous.com/store...?idproduct=115
can anyone give me the links to the other things i would need.
thanks,
Nick
i definately think you could do it.
although i don't know how much an install can cost.
here is something else you might want to add
http://www.dynotunenitrous.com/store...p?idproduct=17
this is already starting to get kinda exspensive, maybe i should shoot for 1 grand without install
i forgot about a bottle warmer
and i forgot to say this are the switches i would want
http://speed-eng.com/store/product_i...oducts_id=6674
but i guess i would just have the bottle open/close and purge not functional untill i got those things.
and this is were i want to mount the bottle
right now im at $653.00 for the kit, switches, and the black version of the bottle warmer that was posted
http://www.dynotunenitrous.com/store...?idproduct=194
http://www.dynotunenitrous.com/store...p?idproduct=24
Here is a window switch and purge that brings your total to 851 with a fpss it would be right around 891. You would probly need colder plugs too but those are pretty cheap thats every thing you would need for a 100 wet shot.
Thanks for the quick replies,
what all goes into installation??? i'm thinking i could do it myself as long as i had some instructions, what all tools and skills are required???
come on guys, what all goes into installation?
and i was reading the FAQs sticky and was wondering if i would need to start using premium gas instead of regular?
Nitrous install is very hard the directions that come with the kit are usually pretty good you need basic hand tools and a drill usually depending on how you set it up but its definatly something you and a buddy could do.
i think he ment to say NOT very hard. As long as you do everything right (and it can be pretty hard to **** up) you will be good. Wiring just sucks.. especialy when you get into window switches...(notice my thread? lol)
i downloaded the car's manual and you were right, it says use premium but you can use middle or lower octanes but it will cause acceleration to decrease.
thanks for telling me that, i'm gona start using premium
Originally Posted by reject
http://www.nitrous-oxide.net/videos/...de_Install.wmv
that helped out on trying to understand what goes to where and other things
that helps alot
I'm up to $732 for everything.
Dynotune wet kit - $369
Dynotune window switch - $129 (You can get one cheaper, I wanted 1st gear lockout)
Dynotune bottle heater - $119 (Again, this is an upgraded one that is automatic)
Dynotune Purge kit+ dual purge kit - $82 (completely optional part)
Jimmy Jams switch - $33 (see above)
All parts were new. So yes it can be done. Why can't you install it yourself? These things are easy.
BTW, on a 75 or 100 shot you won't need to change your tune, upgrade your fuel pump or injectors.
idk, i've always been scared of wiring stuff and electronics
what heater are you geting for 115 that is automatic? the automatic one i was lookign at from dynotune is 139.00 plus another 20 cuz i want it in black
your also not getting the fuel pressure safety switch, thats anotehr 40
