need help planning
Old 06-12-2006, 07:41 PM
94z28L's Avatar
Default need help planning
k guys so im lookin at running a 150 wet shot on my car and these are the things that i plan to get to aid the nitrous set up let me know if i forgot anything, fuel safety switch, WOT switch, MSD digital window switch, blow down tube with fitting, purge valve, nitrous filter, NGK TR6's, bottle pressure guage, AF ratio guage, Fuel pressure guage, a pillar guage pod, and a purge kit.
also sponsors let me know if you would be able to do any kinda package deal for me,
Thanks,
Mike
Old 06-12-2006, 11:13 PM
94z28L's Avatar
no one has any input for my new set up?
Old 06-12-2006, 11:17 PM
_JB_'s Avatar
A window switch.
Old 06-13-2006, 12:50 AM
94z28L's Avatar
wouldnt the msd digital one work for that? sorry pretty new to nitrous, ive done some research on it through out different forums but still am learning
Old 06-13-2006, 12:57 AM
_JB_'s Avatar
oops, my bad. I'm so used to seeing MSD I instantly figured it was for ignition lol. Need a fuel pump though.
Old 06-13-2006, 12:58 AM
_JB_'s Avatar
Oh unless the a/f ratio guage is a wideband, don't waste your money on it.
Old 06-13-2006, 01:29 AM
94z28L's Avatar
wideband it is, anything else you can think of off hand man? i was thinkin a tune for sure
Old 06-13-2006, 01:48 AM
_JB_'s Avatar
I'm unsure about the tune, I've read some people get away with stock tuning and others retard it alittle bit. I'm just getting into n2o myself, I'm just waiting for the stuff to come. Use the search button, I've learned a shitload of stuff here in only a few days.
Oh, if you get electrical fuel and n2o pressure guage, make sure it's a full sweep. Mechanical ones are good, but I don't want to run a gas line into my interior.
Old 06-13-2006, 02:06 AM
94z28L's Avatar
tracks wont allow you to run a gas line in to the interior anyway
Old 06-13-2006, 07:13 PM
94z28L's Avatar
thanks for the input ad help man, no one else tho?
Old 06-13-2006, 09:04 PM
Robert56's Avatar
Sounds like you have your bases covered to me. Give Scott a call at 954 650 7951 and he can set you up with a package deal. We carry NX and Cold Fusion, some really nice wet kits by both.
Robert
Old 06-13-2006, 09:40 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
Thanks,
Mike
Mike,
I will try to help you out!
Wet Kit $379 - all our kits include a WOT switch
http://www.dynotunenitrous.com/store...?idproduct=115
Fuel Pressure safety switch $39.95
http://www.dynotunenitrous.com/store...?idproduct=135
I would use our window switch rather than the MSD though we do sell both. Our switch is $129 and offers the option of 2 stages also includes a built in TPS switch and a multi gear lockout feature.
http://www.dynotunenitrous.com/store...?idproduct=194
Blow down tube and fitting $29
http://www.dynotunenitrous.com/store...p?idproduct=97
Complete wideband setup with one of the most accurate gauges on the market $279
http://www.dynotunenitrous.com/store...?idproduct=149
Electric digital FUel Pressure gauge to match $159 - accurate to .1PSI
http://www.dynotunenitrous.com/store...p?idproduct=19
Nitrous filter $29
Bottle pressure gauge on bottle $24.95
http://www.dynotunenitrous.com/store...?idproduct=143
Purge Kit - $69
http://www.dynotunenitrous.com/store...p?idproduct=24
We do not offer plugs at this time or ghauge pods - SUmmit is a great source for these items.
Total with 5% discount for $1000 order - $1081.05
I am sure there are cheaper out there as well as more expensive but the key thing is to match feature to feature and you will see why so many enthusiasts use our products.
Dean
Old 06-14-2006, 12:14 AM
Restricted User
CAT3's Avatar
Mike, I must admit, either you have used the search button A LOT, or you been lurking/asking questions A LOT. Other than the wideband vs. AF Meter, you covered everything I could mention to a newb to nitrous...I give you a Prop for the Nitrous Filter
Old 06-14-2006, 01:47 AM
94z28L's Avatar
hahaha thanks man, i do what i can, now its just a case of figuring out which set up im gonna go with and ordering it
Old 06-14-2006, 02:13 AM
94z28L's Avatar
guess i shouldp probably figure in something like the msd digital 6 so i have a rev limiter to cut off before the stock one cuts off the fuel and also be able to pull a little timing
Old 06-14-2006, 03:16 PM
Nitro Dave's Nitrous Outlet's Avatar
I just responded top your pm. Sorry It took me a while. Im alittle behind.
Dave
Old 06-21-2006, 01:19 AM
BigDB's Avatar
Sry for bring this back but this is what the wondow switch does it activates and disengages the solinoids at the RPMs that you choose with the pills of your choice
Old 06-21-2006, 01:41 AM
94z28L's Avatar
yep pretty much and usually you lock out the spray for first gear
