18 gauge wires
18 gauge wires
Alright I'm almost ready to spray. Everything is hooked up except my WOT switch, my arming switch, my purge switch and nitrous switch. So baiscally all I have left to do is electrical work. My first question is: Is there where do you guys run your 18 gauge wires from your switches to your ground. Is the little hole by your pcm the only place to run it? My second question is: where do you guys mount your WOT switch? I can't seem to find anywhere that it will mount. This is a dry kit BTW
Thanks
Thanks
haha yeah i hooked it up......well jus run it thru the pcm hole again i guess, itll be the easiest. and advanced auto parts has the 18 gauge wire we need..i got it all mapped out and everything man.. u need to call me
