View Poll Results: Nitrous Activation: Would you spray below 3,000 RPM?
Hell yeah, no question I would!
105
19.13%
Yes, but you're playing with fire and she may blow!
55
10.02%
Maybe, but it depends on the system and safety additions.
123
22.40%
No way, you're asking for broken stuff!
266
48.45%
Voters: 549. You may not vote on this poll
Old 04-11-2009, 01:42 AM
  #101
Roger Z06's Avatar
3200 is my magic number!
Old 04-13-2009, 12:17 AM
  #102
pyro719's Avatar
I'm seriously considering lowering my activation from 2800 to 2000, My converter is just to tight and not hitting the tires hard enough.
Old 04-13-2009, 01:54 PM
  #103
Ruckus46Gt's Avatar
question should be how many have done it etc. I already stated I spray my car at 2200-6000. I have a 3k converter and its to tight its the only way I can get it to hit right away. Car isnt going to Bogg either if i had a stick car yea i wouldnt run that low but
Old 04-13-2009, 10:37 PM
  #104
pyro719's Avatar
I agree! who has sprayed lower than 3,000? I'm at 2800 right now and working my way down!
Old 04-30-2009, 12:19 PM
  #105
99_Z28's Avatar
Picking up a dry 100 shot would I be safe without a window switch? I have a 3500 stall but it is very tight, would it zing right up to 3500 if I hit it off the line with a wot switch?
Old 04-30-2009, 04:31 PM
  #106
pyro719's Avatar
I'm sprayin mine @ 2500 now and it loves it! Still not spraying out of the hole yet but very close. Im going to 2200 next
Old 04-30-2009, 04:35 PM
  #107
single digit dreamer
parish8's Avatar
i would always still use a window switch, just keep turning it down till you are happy. spraying at 2000rpm is one thing but wacking the throttle off idle and spraying at 900rpm is bad. that kind of thing can happen without a window switch.
Old 11-18-2009, 10:03 PM
  #108
Silverback's Avatar
I'm betting that if you're activating significantly lower than 3000, your converter is flashing pretty close to it almost instantly, so it wouldn't make a difference what you set your rpm to.
Old 11-18-2009, 10:52 PM
  #109
Ph.D. in HUBRIS
custm2500's Avatar
I have a 2800 stall, set my activation at 2700 and have 239,000 mi. on the ticker. Ran 3 passes with so far and am planning on stroking the motor this winter so no idea how long it would hold this but I would be willing to bet forever.
Just to make it clear I spray off the line.
Old 11-19-2009, 09:25 AM
  #110
Ruckus46Gt's Avatar
i ended up going to 2200 rpms
Old 11-19-2009, 11:03 AM
  #111
pyro719's Avatar
I'm spraying @ 1800rpm's now took my 60ft from 2.0 to 1.7
Old 11-19-2009, 11:09 AM
  #112
mitch cobb racing's Avatar
ive been as low as 1500 i think...
Old 11-19-2009, 11:37 AM
  #113
12 Second Truck Club
WJ MARK's Avatar
I was spraying about 1800 rpm, due to a tight converter and couldn't build any boost at the line so my 60's were like 2.2 or worse. I was also progressive and a baby 50 shot. Not sure how low Id start with a large shot though.
Old 11-20-2009, 12:45 PM
  #114
transam69230's Avatar
http://www.youtube.com/watch?v=4LWZZ...layer_embedded
Do you guys think that I should lower my window based on this video of my launch?
Old 03-02-2016, 09:18 PM
  #115
BooneSS13's Avatar
I know this thread is old but I have a good question. What if you spray at a lower rpm and you have a direct port system on an m6. Would it be any safer since you practically eliminate the fuel puddling issue? I'm talking around 200 shot slipping the clutch off of the line as well
Quick Reply: Nitrous Activation: Would you spray below 3,000 RPM?
