installin nitrous outlet plate kit this weekend. tip?
Old 09-03-2008, 07:46 PM
dawiz's Avatar
Default installin nitrous outlet plate kit this weekend. tip?
ill be installing nitrous outlets wet plate system with a dedicated fuel cell this weekend. any tips you guys can give to aid in the install would be great! by the way its going on a c5 vette.
thanks!
Old 09-03-2008, 07:49 PM
firefighting1101's Avatar
take your time and make it pretty! make sure you solder all of your connections. and good luck!
Old 09-03-2008, 08:05 PM
jetlag's Avatar
wire heat shrink wrap is awesome stuff.
Old 09-04-2008, 07:18 AM
dawiz's Avatar
im looking for vehicle specific tips
Old 09-04-2008, 07:19 AM
Beer99C5's Avatar
Steering Fluid reservior spacers be sure you have them as the F-Body kit does not come with them...The Corvette kit should have them.
Use a turkey baster to drain the Power steering reservior, get as much out as you can. The reservior slides out by lifting up. I just cut the hose because my fat little (oxmoron there) Hands could not easily pry up the old hose (even with the clamps loose).
When you put the reservior back on (spacers and bracket bolted in place), put the hose clamps on loosely, tighten the top one that is on the reservior and lubricate the end of the hose going on the nipple, use the force of you pushing down on the reservior to allow the hose to get pushed over the nipple...then tighten both clamps (make sure they are angled so you can get the screw driver or nut driver on them.
Old 09-04-2008, 07:32 AM
KCJeff's Avatar
Everything Beer said! He was very helpful with my plate install.
Also, longer power steering fluid reservoir bolts (because of the spacers). We found some at a local auto parts store, but you don't need that interruption/delay. I think they were .50 x 105 mm.
Old 09-04-2008, 08:17 AM
8 second mod
Noyzee's Avatar
12v switched is right under the dash on the pass side. there should be 2 wires dead end cut one is switched. thats a great place to tap in.
also like said above solder everything and make it look nice the first time, it helps allot.
Old 09-04-2008, 09:15 AM
Beer99C5's Avatar
Here is what I used to get me going for my install, I changed alot up, but this was a great start.
Hot Rod C-5 Nitrous Install Article
Old 09-10-2008, 05:45 PM
Nitro Dave's Nitrous Outlet's Avatar
Jeff,
Our C5 Specific system comes with the needed hardware to do this.
Dave
Old 09-13-2008, 06:24 AM
dawiz's Avatar
well last weekend cancelled due to hurricane prep. so today is the day. we will get started in about an hour. thanks for tips!
especially the switched power!!
Old 09-19-2008, 10:27 PM
dawiz's Avatar
well, everything is together but the damn fuel pump in my fuel cell is dead! once all the wiring was done we armed the system and no pump? checked voltage...yup,12 volts. disarmed, checked voltage...nope so the arm/disarm guage is working fine.
remove the pump from the cell, bench test...dead? check continuity? nothing!
hopefully it will get covered under warranty since its brand new.
guess im not spraying this week!
one good thing though. i am 100% getting an electric fuel pressure guage to mount inside the car so i know if my pump is working before i spray!
