suggestions please
Old 09-15-2008, 09:34 PM
z28rob18's Avatar
Default suggestions please
im planning on buyin a nitrous system and would like some opinions here. my car and mods are in my sig. and im lookin to spray a 100 shot for now. wat brands u suggest and wet or dry. im lookin for a safer system i no its only unsafe wen the mixture leans out but i figured id still ask for safe. thanx for any help
Old 09-15-2008, 09:54 PM
SuperSlow02's Avatar
I use HSWs products, great stuff
Old 09-15-2008, 09:58 PM
Nitro Dave's Nitrous Outlet's Avatar
There are alont of different brands and styles available. As far as wetvs dry I suggest doing some home work and determain what best fits your needs. Then decice what style and brand system will work for you.
Here is a great read to understand the difference between wet vs dry from a neutral standpoint.
http://www.nitroustech.com/forums/showthread.php?t=92
Here is a great read to understand what the accessories do that need to go along with the system.
http://www.nitroustech.com/forums/showthread.php?t=2
If I can answer any questions let me know.
Dave
Old 09-15-2008, 10:53 PM
myfast70's Avatar
You may want to look at the HSW dry setup, very easy to use and comes with the interface for tuning the AFR, if you ever wanted to go wet you would just buy a fuel solenoid and you'd be set and you could still use the interface for fine tuning. They also have a completion kit that will give you everything you would need. The window switch that comes with the kit is awesome!! It's a window switch, lean shutdown switch, multi gear lockout and more. They have some of the best cutomer service around!
Old 09-16-2008, 02:46 AM
jmill96Z's Avatar
I like wet kits. From my experience, nozzles don't hit as hard as plates. So, if you are spraying off the line with stock parts, the nozzle(s) could make that 10 bolt with 4.10's last a little longer.
If you want it to hit hard, I know it's a little dated but I had really good results with the Nitrous Works plate on my LT1
Old 09-16-2008, 08:35 AM
ShiznityZ28's Avatar
Its an LT1' and I don't see injectors on the sig. That car is probably already short on them . Get a wet plate from daves or your going to have to upgrade injectros and get it tuned for a dry.
Old 09-16-2008, 08:49 AM
8tsixt's Avatar
I am using HSW and love it!
Old 09-16-2008, 09:35 AM
If on a budget our Brand X single nozzle systems are hard to beat. If you want the best of the best I would look into the Nitrous Outlet plate LT1 plate systems. The plate gives the best attomization with the LT1 intake and also makes for a super clean install. The entire system is designed to flow and take abuse. This system will produce over 400 Hp.
Dave
Old 09-16-2008, 09:46 AM
z28rob18's Avatar
alright thank u i am on a budget but i was lookin into that plate system my budget allows for spendin about 700 on nitrous
Nick@HSW's Avatar
Looks like you're not too far from us. Let me know if there is anything I can help you with. Thanks.
Nick
Old 09-16-2008, 09:53 AM
z28rob18's Avatar
where u guys located?
Old 09-16-2008, 09:54 AM
Nick@HSW's Avatar
Right north of Philly in Warminster PA.
Nick
Old 09-16-2008, 10:02 AM
z28rob18's Avatar
alright i might wanna come out some time after i get the money for a kit
Old 09-16-2008, 11:05 AM
You could do the Brand X system and add the Nitrous Outlet plate conversion. Then use brand X accessories as well. That would get you close.
Dave
Old 09-16-2008, 11:11 AM
z28rob18's Avatar
close to budget? do u hav a link to these systems and conversion?
Old 09-16-2008, 05:27 PM
Yes sir..
This is the Nitrous Outlet plate system-
http://www.nitrousoutlet.com/catalog...roduct_id=2806
Brand X single nozzle-
http://www.nitrousoutlet.com/catalog...roduct_id=2891
Nitrous Outlet Plate conversion-
http://www.nitrousoutlet.com/catalog...roduct_id=2808
Brand X single stage window switch with built in TPS
http://www.nitrousoutlet.com/catalog...roduct_id=2885
If this fits you budget this is a good accessory package-
Brand accessory package- We sell these accessories individually as well.
http://www.nitrousoutlet.com/catalog...roduct_id=3241
Dave
Old 09-16-2008, 05:32 PM
Chhh Chhh's Avatar
bunch a bad *** deals from our sponsers, call them and talk to them each see who can give u what. depending on wat u want.
z28rob18's Avatar
this is all real nice can i buy the brand x single nozzle and use that for awhile b4 using the plate
Old 09-16-2008, 05:35 PM
You bet you can. You can always add the conversion later.
Dave
Old 09-16-2008, 05:47 PM
z28rob18's Avatar
alright im thinkin bout doin this how much would shipping be on just the brand x and how long does it usually take to arrive
