cig lighter used for 12 volt?
if i use the lighter for my nitrous switch can i also use it for the purge or should i only use one switch on the lighter and find another for the purge? (the power is orange right i have my bat out and dont feel like putting it back in yet, to test)
I wouldn't recommend hooking it up to the cigarette lighter. I recommend running an add-a-fuse into the fuse block (make sure you're adding it to a switched fuse) and running the purge off of a relay.
Nick
Nick
