rear ends???
Location: Stationed at NAS Whidbey Island in Northwest WA.
rear ends???
Im sad, It has finally set in that I cant make both tires spin together when I smoke them. I was sure that a trans am could do it stock. I wish there was somthing I could do that is not too expensive. :sad: please help and I will you forever.
P.S. stop at me
P.S. stop at me
I had that problem with the stock rear end, It means the posi unit is toast. If you have the money I would go with a 12bolt or 9 inch, but if not mybee look into the difrent types of posi's that have already been talked about.
How much would a carrier cost? Where could I get one?
Originally Posted by DrEvyl
Trans Ams have a posi differential stock. If you car can't do it, your carrier is probably fried. There are a number of options in replacing it...
One would be to just replace the stock one... but personally I'd recommend using an Auburn or a Eaton carrier to replace it.
Originally Posted by WAHUSKER
If the rear end is not broken & working poreprly, both tires should spin.
But if only one tire is spinning, that is definitely something wrong and needs to be fixed.
whats the cheapest proper way to fix it. I just dont have the money for a new rear end, or 12 bolt or whatever. Im not too car smart bit with help I can be .
Originally Posted by Tranzor_Z28
Not necessarily... I tore up the posi in my 12 bolt and looking at the video from that day at the track, both tires were spinning just fine... but the rear end was definitely screwed. It just had trouble unlocking...
