Anyone with knowledge of Trailblazers or Envoys
I (foolishly) offered to change the oil on my Mom's '05 4WD Envoy SLT (the 4.2 6 banger). Wow, what an experience........finally figured where they hid the oil pan and drain plug, no problem with that but DAYUM!!!!!!!! The oil filter is one biaaaatch to remove/replace.
Does ANYONE have any experience with these and how NOT to drown yourself/cover the undercarraige & garage floor with oil? Please?
I looked on this site's "truck" area but they seem to deal only with full sized or the SSR/Trailblazer SS versions.
Help please?
I did get it done, was just hellasiously messy is all and I would like to avoid that in the future when I get recruited to do it again.
Help please?
Heh... that's like changing the oil in my wife's CR-V. What a crappy experience that is. The oil filter is way up high on the back side of the engine block, I have to work my arm up past the suspension parts to get to it... and then when you remove it, oil runs all down the side of the engine block and down into the holes on the k-member, and also onto the catalytic converter!
What kind of morons put an oil filter where oil is going to get on everything, including the cat??? Don't they know the oil's gonna burn up on that cat... can we say fire hazard?
Yeah, after discovering the hidden panel covering the oil drain plug and the extremely recessed oil filter, it was a MESS!!!!! The dran plug was fine, it was removing the filter that was a disaster.
Anyone???
Anyone???
teh PuRpL3z
My Colorado was fairly similar, they'd actually even designed a thing into the front suspension cross member that was there to collect oil and channel it down off the cross member when you removed the oil filter. It was pretty much impossible to change the oil without making a huge mess.
The GTO is nice, other than having to remove the 30 lb, 1/4" steel skid plate just to get at the drain plug and filter.
Are there no msg boards for these vehicles?
Here's one:
http://chevytruckworld.tenmagazines..../forum.asp?527
As for the filter--yes, you're going to get dirty. No way around it.
teh PuRpL3z
Originally Posted by Rottluver
Have to unscrew a plate (part of the offroad skid pan protection I presume), remove the plate and then unscrew the drain plug....no problem. BUT the filter was up almost 8-10 inches and wedged in between the oil pan and the frame and sway bars and other susp pieces. Made a huge mess all over my new floor.
Originally Posted by Jon A
Here's one:
So is it a hard plastic skid plate like my Colorado had? Or is it metal? The one on the GTO is like tank armor, sucker is heavy... but it offers a lot of protection to the oil pan and filter. You'd have to hit a huge rock at high speed to even phase it. Once it's off, though, the filter and oil drain are a lot easier to access than the F-bodies are.
The oil drain plug was RIGHT THERE when I moved that piece out of the way but the filter is up about 10 inches and there are a couple immoveable objects between it and freedom.......meaning that the oil drips all over everything when you take it off.....and this was after taking off the "oil fill" cap AND having already drained the pan itself.
Not too mention the ***-monkeys who did her 1st oil change decided to put that filter on with the strength of a thousand men............NO way to get a filter wrench up in there and get any kind of grip on it........so that was fun.
Originally Posted by Rokko
Next time, just pick it up and drive it to Jiffy Lube, done deal!
But thanks for the advice.
Just be glad it's not one of the 06+ non-turbo/non-H6 subarus... the exhaust manifold wraps around the oil filter and there's barely enough room to get a pair of filter pliers in there.... so guess who's hand gets burnt to **** when they have to tighten it they had a good design for years why'd they have to change it!!
Tech Addict
**** Jiffy Lube and their fucked up practices and their fucked up ways of leaving the radiator cap unscrewed so all your coolant spills out and **** them and their high prices.
How about Q-Lube, or take it to the dealer. If that nightmare was mine to do the oil changes on I'll tell you what, it'd be somewhere else for that nasty chore besides my garage or driveway. Drive it somewhere you trust and let them deal with it. Money well spent in my book.
my tahoe is kinda stupid too. It's not hard to get to, but the filter is on at an angle (has an oil cooler too) so when you take off the filter, oil just pour right onto the front drive shaft.
Wow, I do believe we found something that gets the retired po-po all wound up.
I would rather do this for my Mom then have her waste tons of $$ at Jerky-Lube or any other place. I just gotta get a pan for my garage floor so it doesn't get stained. I was lucky yesterday.
You said take it somewhere I trust, well that is the key word, I DON'T trust any of those quick change places one bit. No biggie, just lookin to see if anyone had any ideas on how to remove the filter without wearing half a quart of oil.
Yeah, Jiffy-Lube and all the "quick oil change" places have a special place in hell with me.
I work at a quick change place lol well Carter Quick-Lube hehe just the quick lube portion of the dealership but still lol
The radiator incident was with an aluminum LS1 and it was the day before the new owner was taking delivery.......and it only had about 1 quart of fluid left in it when I noticed the problem. ******** were pissed cuz I didn't want them to "flush" the radiator so they never recapped it after preparing to flush it prior to asking my permission in the first place.
Needless to say, those are just parts of only 2 stories but I will never go to another one of those places again if I can help it, regardless of who I know working there.
You can try www.trailvoy.com or www.envoystuff.com or www.envoyforums.com to find more info on this stuff....good luck!
So did you get oil on your face when you changed that filter? The first time I changed the oil in my wife's CR-V, I didn't anticipate a bunch of oil flowing into holes on the K-member... I was more concerned with keeping the oil off the cat and exhaust pipes. I made a pretty good shop towel barrier on those things, but the oil dripped on to the k-member (which I was prepared for and positioned my catch pan appropriately), but I forgot about the holes on the top of the k-member.
So, the oil flowed into that... and wouldn't you know, my head was a little further 'downstream', right under another hole. You guessed it... warm oil flowed all over my face, got a little in my eye, mouth, nostril, etc... and of course, it happened right when I got the filter completely off, so in my shock, bad taste in the mouth, and burning sensation in the eye, I dropped the filter... and of course, it's still full of oil. It clatters on the garage floor, and because my garage has an ever so slight slope to it, the filter rolls down the length of the garage, leaving a nice river of motor oil behind it.
But I'm in the same boat as you... I'd rather put up with that crap than take one of my cars a quick lube place. I especially cringed when I heard stories on the Honda forums about those knuckleheads at the quick lubes not putting the filter on right and having it come loose, dripping oil on the cat and causing a fire... sounded like that happened to more than a few of those people.
