how many shades of pewter metallic are there?
I have a '99 pewter metalic z28 camaro, wanted the hood painted and realized there may be at least 6 different pewters?
is it:
11U/WA382E light pewter metallic
or could there be many types of this shade?
is it:
there are two stickers on your driver door jam. it is the smaller one on top of the other, one has the vin, the tire pressure and the gvwr ratings on it(larger). you need to look at the bottom of the other one(smaller).
you will see bc/cc and then your code, if your car is pewter it will be the 11u i believe. also, take your fuel door to the paint supply so you can get a more accurate match.
thats what it seems like. I've looked at the door, referenced that number, and still different shades came up. The guy at the shop said that it all has to do with how long the paint sat at the factory, fade over time, and other factors...
thats why you take your fuel door for a more accurate match. they will mix the paint according to the code and then match it according to what your paint has or has not done over time.
the gas door is actually a bad idea if you're painting a hood. The gas door is metal, the hood is glass, and the fenders/bumper are plastic. The different materials fade at different rates. The quarterpanels may also have been repainted, which would make matching the color to the gas door pointless. Dupont has a camera that takes a picture of the color on the car, but it's not very accurate. Whomever paints it will need to do a spray out panel for an accurate match. Also, blending the fenders and bumper is recommended if you're painting the hood. There may be 6 or 7 varients listed for the color, but I can bet none of those will be dead on. They will need to be tinted. 382E is always a bitch
