Forged merkel 408 long block , ttp 347 short block , fuel system, excel dfi ect..
Category: Engine - Complete Motors
Price: $5900
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): NY
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Eagle rods/arp 2000 bolts, mahle pistons, arp main studs/bolts
Slp oil pump
Merkel racing built fully forged 408 long block - over 12k invested (have receipts)- 5900 obo.
Includes
Lunati Pro LS1 408ci Rotating Assembly 4.030" Bore -38cc Dish Pistons 4.000" Stroke 6.125" Rod Length 8.5:1 compression ratio Heads Fully Ported LS6 Heads Comp Cams Lifter Type 'R' Pro Magnum Hydraulic Roller Lifters Comp Cams 7.400 Pushrods Comp Cams Dual Valve springs REV Valves Intake 2.005 + 70 Long REV Valves Exhaust 1.570 + 70 Long ARP Head Studs Cometic Head Gaskets
-ASP Underdrive Pulley
Custom grind turbo cam
Slp oil pump
Double roller timing chain
- made 812 hp@ 12psi (has a lot more left-built for 1200+hp)
You can see how clean the motor is in the pics.
Complete fbody Racing Fuel System -1200 (will split up make offers)
-Weldon Fuel Pumps and Weldon Fuel Filter -10An Fuel Lines W/Aeromotive Fuel Regulator
-12 Gallon Aluminum Fuel Cell Bolted in place where the stock tank used to be
Accel dfi w/ ls1 module and 3 bar map sensor includes stock Fbody harness- 1200
Meizere electric waterpump - 350
Original SLP ultra z hood in black with a few cracks in paint. needs to be repainted. - 500
Borla Catback (few minor dents sounds great)-350
