Cylair gms/cyl calc pid EFI V6
Go to configuration file.
In sae_generic.txt
1. You need to add a new g/cyl unit that is not Metric nor Imperial , i.e. its "units system" in None like this
#Flow rate
gps Metric g/s "Grams per Second"
lbpm Imperial lb/min "Pounds per Minute"
gpcyl_jp None g/cyl "Grams per cylinder"
gpcyl Metric g/cyl "Grams per cylinder"
lbpcyl Imperial lb/cyl "Pounds per cylinder"
2. You need to add a new calculated parm in calc_pids.txt that uses the new gpcyl_jp units.
#Units Low High Fmt Expression
*CLC-00-1
gpcyl_jp 0.0 1.5 .2 "{SAE.MAF.gps}*15/{SAE.RPM}"
#gpcyl 0.0 1.5 .2 "{SAE.MAF.gps}*15/{SAE.RPM}"
lbpcyl 0.0 1.5 .2 "{SAE.MAF.lbpm}*1.98416/{SAE.RPM}"
3. You need to change the CYLAIR PID like this:
#Calculated parameter PRN SLOT Units System Description
#CALC.CYLAIR F600 CLC-00-1 "gpcyl,lbpcyl" Air "Air mass per cylinder"
CALC.CYLAIR F600 CLC-00-1 "gpcyl_jp" Air "Air mass per cylinder"
In sae_generic.txt
#Flow rate
*CLC-00-1
Re: Cylair gms/cyl calc pid EFI V6
In sae_generic.txt
#Flow rate
*CLC-00-1
In sae_generic.txt
#Flow rate
*CLC-00-1
joel
For now. After looking at all the calculations for VE, this should be childs play. It's adding a total of 3 lines. I guess all the tuning programs available are/were perfect.
joel
Restricted User
The CYLAIR calculated PID is already configured and included in V6.
However, if you select Imperial units in EFILive V6 then CYLAIR will show up as lb/cyl not g/cyl.
The first post is what you need to cahnge to get CYLAIR to display g.cyl even if your units are set to Imperial (instead of Metric).
Alternatively you can set it up like this - by editing the Configuration\calc_pids.txt file:
1. Create a new UNIT for grams per cylinder and do not allocate it as either metric or imperial, set it's units type to none.
<font class="small">Code:</font><hr /><pre>
*UNITS
#Code System Abbr Description
cylair None g/cyl "Grams per cylinder"
</pre><hr />
2. Create a new expression that returns the cylair units that you just created:
*CLC-00-1
cylair 0.0 1.5 .2 "{SAE.MAF.gps}*15/{SAE.RPM}"
</pre><hr />
3. Create a calculated PID that is based on the expression that you just created:
CALC.CYLAIR F600 CLC-00-1 "cylair" Air "Air mass per cylinder"
</pre><hr />
Regards
Paul
*UNITS
</pre><hr />
*CLC-00-1
</pre><hr />
</pre><hr />
Regards
Paul
