P0107
That's a low voltage code. You have an open circuit. Either the 5 volt reference or the signal return.
It's possible the female pins in the connector have opened up. It's also possible there's a broken wire somewhere. My first suggestion is to check the female pins closely, and see if they've "spread" open.
