o2 bank 1 and bank 2 #1 pcm wire ?????
Old 10-09-2003, 01:05 PM
Assassin's Avatar
Default o2 bank 1 and bank 2 #1 pcm wire ?????
for hooking up o2 guages to each side, should I run a wire down to the o2's or is there a particular wire on the pcm that would be much easier to "tap" into?, wich ones for both the front censors?, cant remember off the top of my head but there's 2 sets of 32 wires right, 1st on top and 2nd on bottom?
Old 10-09-2003, 01:55 PM
WS6FirebirdTA00's Avatar
Default Re: o2 bank 1 and bank 2 #1 pcm wire ?????
trying to hook up an air fuel gauge? if so its the purple wire on the o2's. thats all i know so hopefully thats what u need lol
Old 10-09-2003, 02:26 PM
Assassin's Avatar
yeah, hooking up air fuel guages, I wuz hoping to splice into the pcm wire instead of running wire down to each side of the motor, make things a little easier and cleaner!
Old 10-09-2003, 06:01 PM
Assassin's Avatar
nobody?
Old 10-09-2003, 10:18 PM
eboggs_jkvl's Avatar
You can try here:
http://www.ls1.com/forums/showthread...;threadid=1040
ITT
Old 10-10-2003, 05:07 AM
Drake's Avatar
Here's the best PCM pin assignments list I've found.
http://www.ls1.com/enginetorques.htm
On my 02 LS1, I ran a tap on numbers 66 and 69 to get B1S1 and B2S2. Seems to work wonderfully.
