tuning for gear
Old 02-26-2009, 09:37 PM
srpoweredcoupeNWH's Avatar
Default tuning for gear
i have a 98 Z28 a4 just put a 3.73 gear in it and i am using efi live to correct the speedometer but now WOT it wont shift just hits rev limiter what else do i need to adjust to get it shifting right. also normal driving it carries all the shifts up more. any help will be greatly appreciated thanks
Old 02-27-2009, 03:47 PM
no one has had this problem
Old 02-27-2009, 06:44 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Check your MPH upshift settings....they likely need to be lowered.
Generally you will not get the commanded RPM shift until you have met the minimum MPH for the upshift.
If you're MPH settings are based on the stock 2.73 or 3.23 gears, you'll need to lower them by the same % as you increased the gear ratio.
5_02ls1's Avatar
start by lowering your shift rpm....lower it 100 rpms at a time till it shifts.......not a hard fix....
Old 02-27-2009, 06:46 PM
5_02ls1's Avatar
on my 98 lowering mph wouldnt work.......but may have somthing to do with me having a stall....idk.......
Old 02-27-2009, 06:55 PM
LS1TECH Sponsor
foff667's Avatar
Probably the speedo tables need adjusting as well as the shift point tables...sometimes punching in what things "should" be doesn't always work as well as you'd like
Old 02-27-2009, 08:58 PM
5_02ls1's Avatar
yeah my commanded shift rpm is always 75-100rpms off from where its actualy shhifting when data logging.....you just have to play with it till you get what you are after.....
Old 02-27-2009, 10:08 PM
Mike454SS's Avatar
It sounds like the shift tables didn't scale properly if they did at all...usually with gears I find a direct scale of the tables doesn't result int he car being as fun to drive as it could be.
Play around in the tables that decide what MPH shifts occur at...first scale them to get it working, then as you drive it when you think "it should shift now" adjust the tables more so that it does.
Old 02-28-2009, 08:17 AM
thanks for the help ill try it out and see what happens
