hp tuners users
hp tuners users
Im making a custom harness that i got out of a 2000 trans am. Im planning on using hp tuners. What sensors can i eleminate so i can make the harness cleaner? For example there is like 4 o2 sensors. Im planning on running wideband so will i need the connectors on the pcm for 4 o2 sensors or what. also the knock sensors will i be using those as well or can i eleminate them too. thanks.
The only sensors that you absolutely have to have are the MAP and crank sensors. You can find ways around just about every other sensor, though I wouldn't recommend going that far.
Best thing would be find out what all of them do and decide which ones you need/want and which that you don't.
For SD you don't need the MAF. You don't need any of the O2s, not having the front ones makes a little more work to keep the car right all of the time but you don't have to have them. It's also a good idea to keep the knock sensors. Anything else?
