P0140, P1133, P0160 Help please!
I just scanned my 01 ws6 for codes and this is what I came up with. The car no longer has cats or rear o2 sensors. Can someone please tell me what needs replaced. Thanks! Also is my car ok to drive with these codes?
1.)P0140
2.)P0160
3.)P1133
1.)P0140
2.)P0160
3.)P1133
did some research and heres what I found. but I still have a couple of questions
P1133- A/C pressure sensor high volts or o2sensor bank 1 sensor
Does this mean my front passenger side or front driver side is going bad?
P0140- o2 sensor no activity detected bank 1 sensor 2
P0160- o2 sensor no activity detected bank 2 sensor 2
the second 2 codes are because of running no rear o2's correct?
From the manual: The PCM determines that within 100 seconds the HO2S lean to rich switches are less than 30 and rich to lean switches are less then 30.
More than likely you need a new O2. Did you just install long tube headers to the car?
headers were put on the car approx. 800 miles ago. The passenger side was put on about 4000 miles ago and it was just transferd from the old manifolds,guess its time to change the driver side now. I have no idea how many miles it has on it but I have read on here that when you put headers on these cars they will eat you o2s.
