Oil pressure displays on gauges, but not on AutoTAP
For some reason, although my oil pressure reads good on the Trans Am gauge, my AutoTAP is showing zero oil pressure. AutoTAP says it's set up to display a 0-5V signal for oil pressure. Anybody have any idea why the oil pressure isn't coming through to the AutoTAP?
if autotap runs through a dlc, and your working with a 4th gen trans am. Then the pcm never sees a oil pressure signal so it cant send oil pressure through the dlc. the sensor is only hooked to the gauge, it never goes to the pcm.
FYI, it's in a '71 Chevelle running '99 T/A running gear and electronics, and yes, the AutoTAP runs through the DLC.
Thanks again for your help.
